4x4 conversion
Old Apr 25, 2006 | 10:11 PM
brokenshocker's Avatar
brokenshocker is an unknown quantity at this point
Default 4x4 conversion
I have a 95 4-door with 2-wheel drive and was would be involved in coverting it to 4-wheel drive.
Any help appreciated, thanks.
Old Apr 26, 2006 | 12:13 PM
Hanr3's Avatar
Default RE: 4x4 conversion
Welcome to the site.
Tranny- Convert your 2wdr to 4wdr by swapping the output shaft and tailhousing to the t-case adapter, or replace teh tranny with a 4x4 unit.
T-case- you'll need one. Plus you will need to modify or maove your current tranny cross brace. Plus you will need a front driveshaft and shorten your rear driveshaft.
I wouldn't even mess with a factory S10 front axle set-up. I would instead cut all the IFS stuff out and install a solid front axle. Check out this site for more info.
http://www.s10extremist.org/
Old Apr 27, 2006 | 01:21 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
the tranny output shaft is different lengths from the 2wd to the 4wd so an entire new tranny would be in order.....also alot of other stuff...you'd be better off selling your 2wd and buying a 4wd
Old Apr 27, 2006 | 10:38 PM
Hanr3's Avatar
ORIGINAL: smdepew1976
I could make a pretty strong case against that. Depends on how he intends to use the truck once its a 4x4. But if he is just looking for a factory set-up. Your right, sell it and buy a 4x4.
Old Apr 28, 2006 | 03:40 AM
right unless he's going to SAS it
Old Apr 30, 2006 | 01:28 AM
Hanr3's Avatar
Sounds like were on the same page.
Old Apr 30, 2006 | 01:32 AM
4lowlife's Avatar
I converted mine to a 2wd. I removed the front driveshaft. I want to see if I can get 1/2 mpg increase. 40 miles so far and no difference.
Old May 1, 2006 | 02:19 AM
Hanr3's Avatar
Ummm. the front dirveshaft doesn't spin when the truck is in 2wdr. If you want to gain mpg, you need to remove the center chunk in the front axle.
Bobcat13
Nov 10, 2013 06:03 PM
blazer206
Lowering Tech
38
Jan 15, 2011 11:19 AM
ptg327
33
Nov 22, 2008 05:23 PM
bigjohn1139
Jan 17, 2008 12:27 PM
76BadSign442
Feb 1, 2007 11:12 PM
