98 blazer with problems
Old Mar 28, 2007 | 03:16 PM
kkushner4474's Avatar
kkushner4474 is an unknown quantity at this point
Default 98 blazer with problems
my freind has a 98 blazer 4.3L auto
the rpm gauge jumps all over the place if u nail the throttle, it is jsut the gauge that shoots all around and the engine dosent
but if you go easy on it it clims normally with the engine
also when you nail the throttle the engine sounds like its going to bog out and stall but dosent
but when easied on the throtle it goes normally
there were a3 engine codes but we cleared them by reseting the ecu
they were P0341, P0340, there was a third but i dont remeber
we just replaced the fuel filter and it helped a little as did resetting the ecu
any ideas???
if you dont know ur codes...http://www.geocities.com/dtmcbride/h...o/obd_dtc.html
Old Mar 28, 2007 | 04:17 PM
nai0013's Avatar
nai0013 is an unknown quantity at this point
Default RE: 98 blazer with problems
Stop nailing of the throttle, treat it like a lady!!!
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
