Air Intake
Hey, i have a quick question! If i was to put a new air intake on my 97 blazer, would it hurt it any way and/or hurt my gas mileage.
RE: Air Intake
if you dont get a good one then it can hurt u but I did hear a rumor not sure if its true that if you JUST do a CAI then it will hurt ur gas mileage.
RE: Air Intake
The problem is that it has to be a CAI (cold air intake), not just a new tube with a cone filter in the engine bay. A *true* CAI will be isolated from the hot engine bay heat (air sucked through the hot radiator) and will draw in outside (ambient) air. Hotter air is never better, no matter how much easier it is to get into the motor.
I did a quick synopsis of the restrictions in the air intake system a while back - Click the link below: https://blazerforum.com/fb.asp?m=18780 I linked directly to the post in that thread with the hard information in it, but there is more information before and after that post that is beneficial as well. |
RE: Air Intake
Oh ok, so what would a new cold air intake do for my car. Better gas mileage, better horsepower?
RE: Air Intake
CAI's will give you a little more HP....and gas mileage but the swart said....you need to have a true CAI
RE: Air Intake
how would you make a CAI on a blazer?? there is no opening in the bottom of the engine bay near the present intake
RE: Air Intake
I had a thought. No one mentioned the fact the HOT exhaust in the EGR pipe that goes into the intake manifold will cancel any "cold air" that enters past the throttle body.
RE: Air Intake
wait what?
RE: Air Intake
It's part of our emission sysytem.
I forgot to mention the PCV that enters the manifold too. I would like to believe the air in there is hot and oily. |
RE: Air Intake
so hot air goes into the intake manifold and there is no way to stop it?
RE: Air Intake
Yes, the EGR gasses are hot as well as the PCV gasses (but not to the same extent as the EGR). Compared to the amount of air entering the motor, the temperature of these sources is pretty insignificant. Couple that with the fact that the EGR valve is closed at WOT (wide open throttle), and you will have pretty much NO power loss attributed to the EGR system when you're rammin' around.
I never meantioned the EGR valve/gasses because of the fact above. The PCM shuts the EGR valve during WOT (or anything over a TPS reading of 70% or 3.3v reading). The PCV is only active when there is positive pressure in the crankcase and as soon as that pressure is released, it closes down again. Will it allow warmer than ambient air/gasses into the intake system. Simple answer, Yes. Will you be able to notice it...? No. If you were really concerned about that, you could take the filler neck off the passenger side valve cover and get a breather filter for on it. Then your PCV system shouldn't really ever open up (unless your PCV valve was bad). |
