a/c removal
Old Dec 9, 2005 | 04:33 AM
S10salvation1's Avatar
S10salvation1 is an unknown quantity at this point
Default a/c removal
I was looking for a way to remove the a/c compresser, replacing the serpentine belt with a smaller one and putting a new pulley on in place of the compresser. Where can i find an a/c delete kit or a pulley to put in place of the compresser?
Old Dec 9, 2005 | 07:54 AM
Default RE: a/c removal
What year and engine are we talking about? It makes a difference. I don't think that A/C became standard until 96-97. You probably wouldn't even need to use a delete pulley if your year had optional A/C. Just get the belt from the parts store that lines up w/o A/C.
Old Dec 9, 2005 | 01:49 PM
its a 1998... im pretty sure a/c was standard
Old Dec 9, 2005 | 03:39 PM
I'm pretty sure it was too, doesn't mean that the S10 also came standard with A/C. The belt that you will need is an 87" belt (stock w/ A/C is 95"). I don't know how the routing will go, but I'm searching for the answer for you.
Old Dec 9, 2005 | 03:43 PM
Now, this may require you to change the front accessory mounting bracket, probably only the drivers side one.
It is possible that you may have to have someone make up an A/C delete pulley. I'll like you to one that is made for a Grand Prix, but you may be able to use it.
#1 = No A/C
[IMG]local://upfiles/667/D69E609CC99442C89A5768EF752D19CD.gif[/IMG]
#2 = A/C
[IMG]local://upfiles/667/BA00C9F2860D43DAA283EF30DD838F95.gif[/IMG]
Just because Blazers came standard with it does not mean that all vehicles that utilize the 4.3L came standard with it. I believe it was still an option on the S10s and the C/K1500's that came with the 4.3L.
Old Dec 9, 2005 | 03:46 PM
I already have the smaller belt, but it doesn't clear the water pump pulley if i simply bypass the a/c compresser. It still has slack on it to so i def. need to put something in place of the compresser if i take it out. Theres a bolt hole underneath the a/c compresser where i think i can mount a pulley but im looking for an easier way then just going ot the junk yard and trying to find something that works.
Old Dec 9, 2005 | 03:49 PM
Ya i figured the bolt hole was for the models w/o a/c i just need a pulley that fits there.
Old Dec 9, 2005 | 03:53 PM
Doesn't get much easier than grabbing a pulley from a junker... Well, I suppose you could order a new pulley from a dealership...
Old Dec 9, 2005 | 04:03 PM
Old Dec 9, 2005 | 04:04 PM
Ya but i cna't find hte pulley fro mthe dealerships all that comes up is the a/c compresser pulley, no a/c by pass pulleys.
