Check engine light
Old Oct 4, 2005 | 07:04 PM
webbyj883's Avatar
webbyj883 is an unknown quantity at this point
Default Check engine light
So, i have a 2000 Blazer with a 4.3, and a code reader and I keep deleting a code that pops up almost every single day that reports a "misfire in cylinder 1". It's always in cylinder 1. Now, I've replaced all the plugs and wires as well, and I still get this code popping up almost everyday. I've noticed the check engine light seems to come on when I'm getting on the highway or accelerating hard through 2nd or 3rd gear. I also tried dumping 2 bottles of fuel system cleaner through the gas because someone told me it may be carbon buildup on the valves and they're not seating correctly (116K miles). Is there anything else I can try?
Old Oct 4, 2005 | 11:08 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Check engine light
injector? could be a sticking lifter. we had a car come in that a cam lobe was worn.
Old Oct 11, 2005 | 02:24 PM
webbyj883's Avatar
Well, it may have been an injector or a sticky valve that wasn't seating right. . . whatever it was was nothing that 3 bottles of concentrated injector cleaner couldn't tackle! Light hasn't turned on since. .. thanks for the tips though
Old Oct 12, 2005 | 05:00 PM
webbyj883's Avatar
I guess I spoke too soon. . . light turned on again yesterday. . . any idea how much fuel injectors run? can you buy just 1or do you have to buy the set on the vortec motors?
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
