engine running funnywhen cold
Old Nov 19, 2006 | 01:19 PM
prototype80's Avatar
prototype80 is an unknown quantity at this point
Default engine running funnywhen cold
past week or so when i crank the blazer it runs rough for like the first 3 or 4 minutes and then it finally steadies back up and runs fine, it has ran fine all year lon but now it is doing this crap. i was thinking maybe the egr is getting stuck because of the cold weather but maybe not. any clues on this?
Old Nov 19, 2006 | 11:23 PM
Default RE: engine running funnywhen cold
Would help to know what you've got...
Old Nov 26, 2006 | 11:49 PM
i have a 4.3 liter tbi
i listed the problem in a thread among other problems up top, i finally got the truck out on the road today......it about stayed there
delete this post please, several larger problems were found
Old Dec 14, 2006 | 01:45 AM
rkorsen's Avatar
rkorsen is an unknown quantity at this point
check for any vacuum leaks...loose, cracked, or disconnected hoses.
also checkout CTS operation
Old Jan 6, 2007 | 05:13 PM
replaced the tps the other day but still running weird, likes to cut off when at an idle, you have to keep your foot on the gas to keep her going when stopped. ill give the engine a second look but i dont think i saw any rotted vacuum lines, the motor was put in a couple years ago and most everything was replaced.
stevenhousden
Jul 6, 2014 05:56 PM
Survivor
Apr 29, 2009 12:00 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
2001Trailblazer
Apr 21, 2008 10:17 AM
as2higpark
Oct 18, 2007 12:18 PM
