Fluid Changes
Old Nov 7, 2006 | 09:26 PM
dambriz81's Avatar
dambriz81 is an unknown quantity at this point
Default Fluid Changes
I got my 02 Blazer 4wd with 65K miles on it and just turned 68K miles. I want to change the transmission fluid, but do I change out any fluid in the transfer case since its a 4 wheel drive? Last car got traded in because tranny went out so I want to make sure my tranny on this one doesn't go out or anything expensive. Thanks.
Old Nov 7, 2006 | 10:06 PM
cody32401's Avatar
cody32401 is an unknown quantity at this point
Default RE: Fluid Changes
im not big on the 4wd parts but i know gear oil smells something nasty when its burnt so you can give it a sniff
im not really sure but i think according to suggested service i think it is 50-60k if heavy 4wd useage but im not sure ill check the list tomorrow
this was on edmunds.com for your truck it has diff oil on the list so i guess yes
http://www.edmunds.com/maintenance/maintenance.do
Old Nov 8, 2006 | 05:43 AM
4lowlife's Avatar
Get the tranny flushed with a machine. The best way to go. But you may want to change the filter too.
The T case can be drained and changed by yourself. What model T case do you have? NVG 233-NP1 or the NVG 236-NP8?
Autotrak II t case fluid is a dealer item only around me. #88861800
Old Nov 9, 2006 | 02:18 PM
dambriz81's Avatar
I'm just going to have the Chevy dealer do the fluid changes so I don't have to mess with it. I haven't checked into which transfer case I have. Is there model numbers on the housing itself? Where can I find the numbers? Thanks.
Old Nov 9, 2006 | 11:08 PM
4lowlife's Avatar
There will be a stamp on the T case. Should be aluminum. It might say " New Venture Gear, Syracuse, NY" And the model number NVG 2??. My plant makes gears for NVG.
Old Nov 13, 2006 | 08:11 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Have the GM dealer do a power flush. Blazer transmissions are not the strongest, and a very good tranny guy has recommended to me that a tranny power flush every 30K miles is about the best way to prevent problems.
project 96
Jan 17, 2010 03:27 PM
TorqueBoy11
Feb 28, 2009 07:55 PM
keithd44
Feb 19, 2008 10:28 AM
