gear changes
Old Jun 3, 2013 | 05:38 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default gear changes
Does anyone know how much it would cost me to have the gears in my rear axle installed?
Old Jun 4, 2013 | 12:14 AM
Twip's Avatar
what do you have in it and which way to do you want to go? my 2wd has 3.42's in it and i think they are pretty bitchin. decent fuel mileage and the truck isnt struggling. you figure that you are going to be buying the gears which will probably cost you at least 500-600. plus labor. which could vary shop to shop.
Old Jun 4, 2013 | 09:09 AM
01blazer16's Avatar
The gears are 3.73 and $180 for them. I'm gonna put them on when I put 31s on it
Old Jun 4, 2013 | 06:11 PM
Twip's Avatar
you have 3.73's now?? if thats the case, i would leave it. you arent going to lower the gear ratio that much i dont think. you will probably end up around 3.42. i know that they make calculators for this sort of thing.
here, check this out. it only takes a second to put the numbers and options in.
Old Jun 4, 2013 | 06:20 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
If you have 4wd make sure both front and rear have the same ratios.As mentioned 3.42 gears are good 3.73 better.If your going to some serious mudding or pulling you want 4.11`s.
Old Jun 5, 2013 | 07:32 AM
01blazer16's Avatar
I'm not because I have a 2wd and all I'm gonna pull is a trailer
Old Jun 15, 2013 | 01:28 PM
01blazer16's Avatar
if I stay with my 3.42 gears will my mpg be effected a lot?
Old Jun 16, 2013 | 05:11 PM
3.42 gears shouldnt affect your milege much,its a good gear ration for hiway driving and not bad for city.if you do more city than hiway then 3.73 would give you better milege.It wont be bad for hiway driving either.I have the 3.42`s in my Jimmy but its 4wd.Its supposed to get 21 hiway and 15 city but I dont know It hasnt been driven in almost 3 years.
Old Jun 17, 2013 | 08:08 PM
01blazer16's Avatar
What if I put 31s on it with 3.42 gears will my mpg be effected more with stock or 3.73?? And by how much if I stick with stock gears?
Old Jun 17, 2013 | 09:47 PM
LeWhite's Avatar
With 3.42and 31 inch tires as well as pulling a trailer the truck will struggle to get into third gear and never into fourth. A big strain on the tcc.
