get some HP
Old May 1, 2009 | 12:38 PM
nyzr21019's Avatar
nyzr21019 is on a distinguished road
Default get some HP
whats a good, safe, and cheap way to get some horsepower out of my 2001 ZR2?
Old May 1, 2009 | 12:59 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
use the search function, this question has been asked/answered countless times.
Old May 1, 2009 | 04:13 PM
rriddle3's Avatar
Amen to that!
Old Jun 11, 2009 | 12:08 PM
blazerguy18's Avatar
blazerguy18 is on a distinguished road
Im cuttin off the cat.... good idea or bad
Old Jun 11, 2009 | 12:41 PM
rriddle3's Avatar
Bad. Please read some of the threads discussing this idea.
Old Sep 21, 2009 | 05:32 PM
jayjen1317's Avatar
jayjen1317 is on a distinguished road
I am new to the blazer's but generaly speaking replace the air intake with a free flowing system just examples, start with maybe a K&N airfilter not sure how available perfomance parts are but you could also replace the intake manifold.
Not quite as cheap but you could either replace the heads with performance heads or just remove the heads you have and take them to a machine shop and get new valves to incude a 3 angeled valve job and port and polish the the heads.
also not sure of the engine specifics but you could probably raise the compression ratio to increase the HP you could probably talk to the machine shop about things that can be done to the heads to help with this.
also you could replace the single exhaust with a dual exhast system and if they make them for this engine headers would help also.
any of these ideas will increase Horse power even by themselves if you can do a combination of all of those you could increase the HP by alot more.
Keep in mind increseing horse power almost always will use more fuel.
hope this helps you or someone else
mudcat
20
May 4, 2011 05:47 AM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
MrJP
Tires and Wheels
Feb 21, 2010 09:49 PM
90K5Blazer
Oct 7, 2009 10:01 PM
GMdesigner
Lifting Tech
Nov 16, 2007 05:05 PM
