How many miles to a tank of gas?
I've seen some threads on here where people say there fuel gauge fluctuates. Well mine does to it can be at a 1/4 tank one second and 1/2 a tank the next so i was wondering about how many miles do you guys get per filled tank ? i tend to fill it up every 150 wondering if i could go more then that
Depends on what kind of milage you are getting. If you've got a 2dr you should have about a 19 gallon tank. Check your milage next time you fill up and using that algebra that you never thought you'd need, figure out how far you can go on a tank.
I normally go about 260 miles to 300 miles on like 7/8ths a tank
BUT>>> I have a 4dr and get about 20-23 ish... because I baby it highway style between home and school....
As stated earlier, measuring miles per tank is pointless. Only miles per gallon matter.
Also, the correct sizes for Blazer gas tanks are: 2dr = 19 gallons; 4dr = 18 gallons
The fluctuations in gauge reading could be pointing to a bad sending unit on the pump.
