How many miles to a tank of gas?
Old 08-27-2009 | 12:02 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
The best i've gotten was 300 miles for about 14 gallons. It fluctuates a lot, depending mostly on when I use a/c. I usually get about 20 mpg or so with mostly highway driving, and 17-18 mpg or so with city driving. Thats with my '94 with 158k miles, automatic, 4x4
  #22
Old 08-27-2009 | 12:28 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
I would like to know how in the hell dude is getting 24 miles a gallon on average? If you could let us all know what you have done I am sure many people would be grateful
  #23
Old 08-28-2009 | 06:42 AM
nervousmini's Avatar
nervousmini is on a distinguished road
No problem. The things I do fall into 2 categories - mod to the truck and mods to me.
mods to the blazer:
1. Tires - I am running Michelin MXV4s 235/65/17, this is more of a car type tire than a truck style tread. I don't go off road and this kind of tire really helps with a low rolling resistance. I inflate my tires to the maximum printed on the sidewall (51 psi in my case).
2. Alignment - I am running 0 toe and 0 camber up front to avoid pushing or draging the tires. The front end was also lowered about an inch from the torsion bars.
3. Clean up - I removed the roof rack and trailer hitch, I'll never use either so I won't miss them. Besides it looks alot cleaner without the rack and is quieter while driving from less wind noise. I also cleaned out the truck of everything I don't really need - no excess or dead weight.
4. Maintinence - fresh filters and synthetic fluids in everything. Also full tune-up with plugs, wires, cap and rotor, cleaned throttle/afm/injectors.
mods to me
1. Slow down - I stick to the posted speed limit in the right lane. And no I am not the guy doing 30 in a 45 or 50 in a 65. I choose the roads I commute with to avoid the 65mph freeways, speeds over 55-60 are a killer for aerodynamic boxes like a blazer - avoid it.
2. Keep a steady speed. Instead of racing to the light I go the the speed limit and then maintain it. Let the truck coast whenever possible.
3. Keep an eye on the instant mpg gauge in the info display and try to maintain a target number as best as you can start with an easy number you know you can hit then raise it by 1 when you can.
There are lots of techniques and driving skills (these are just a few) that can help you improve your gas mpg, for the rest and great support like I found here at blazerforum go to www.cleanmpg.com and read the "hows and whys of hypermiling" article, here is the link http://www.cleanmpg.com/forums/showthread.php?t=1510
Yes, I know that Hyper word had a bit of a negative association - but this is the original core group that pioneered allot of this and they DO NOT advocate or suggest unsafe or illegal activites like drafting, running stop lights/signs, ect.... I'm not only saving gas and money, but my truck will probably last longer and I also feel allot safer and less stressed when driving.
If you have any more questions be sure to let me know.
  #24
Old 08-28-2009 | 08:36 AM
mr.vls's Avatar
mr.vls will become famous soon enough
I get about 400 miles to the tank. Avg about 20-21 MPG. (19 Gal Tanks)
  #25
Old 08-28-2009 | 05:03 PM
papacope's Avatar
I can go about 250 miles on a tank with the mods listed in my sig. consider that my subs and box weigh about 130lbs too
  #26
Old 08-29-2009 | 08:20 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
****, I get 285-300 miles from anywhere between 14 and 17 gallons. Depends on how I drive.
  #27
Old 08-31-2009 | 08:57 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
just did a tune up and getting worse then before. was getting 17-17.5
put a vac gauge on it and changed the sparkplugs and now getting 15.5
i checked all the boots and yes it is running on all cyclinders. i know there will be people sayin hey stupid your only runnin on four or five. Never changed the fuel filter and i got 113,000 on it so its due for one and i heard changin the pcv valve can help also. anybody know of blazers suddenly dropping off like this.
  #28
Old 09-02-2009 | 04:40 PM
Banned
checked again today and getting 19.4 . what the heck is going on
  #29
Old 09-30-2009 | 07:52 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
yea i suggest getting the pump and sending unit replaced, obviously the float contacts are going bad, not a bad job to do either
  #30
Old 10-01-2009 | 05:20 PM
Banned
thats on my to do list
for know its stayin steady right around 19
update: i ended up changin fuel filter and pcv valve
Quick Reply: How many miles to a tank of gas?
