hypertech superchips jet chips. are they ok?
hey guys im looking into a chip for my truck but im not sure if i want to do this i dont want it to hurt anything on my truck and i want to make sure its not a waste of money any feedback would be great thanks
RE: hypertech superchips jet chips. are they ok?
Well, that all depends on what you want do happen... A hypertech tuner is a less restrictive tune than the factory programming and it is quick and easy to apply. I do believe there are other hand-held tuners that are also available, but you'd need to read reviews from people with your specific vehicle to get a grasp of which one is better.
There is always the option to have a custom PCM tune done, but unless you have a tuner close by, most require that you send in your stock PCM to have it modified. And if you want to get hardcore and have some mods that require a tune to run properly, there is always the custom dyno tune where the tuner would modify the values to make max hp for YOUR engine and mods using a dyno to verify the changes and monitor the systems more closely to make sure that you won't have problems from the tune. |
My friend is a diesel mechanic for Ford. He said that a lot of the aftermarket chips available for diesel engines will shorten the life of the engines if not installed properly. A lot of them require mods to the exhaust and/or intake systems. You also may need to change oil and filters more often. I'm guessing that modifying a gasoline engine is not much different. You're just going to have to read up on the different products that are available.
i have a 94 s10 blazer with the cpi motor and im looking for a chip i have headers and a k&n intake with a 180 thermostat and a obd1. what would be a chip thats most worth my money?
ORIGINAL: Brian J. Lesko My friend is a diesel mechanic for Ford. He said that a lot of the aftermarket chips available for diesel engines will shorten the life of the engines if not installed properly. A lot of them require mods to the exhaust and/or intake systems. You also may need to change oil and filters more often. I'm guessing that modifying a gasoline engine is not much different. You're just going to have to read up on the different products that are available. I like my Hypertech Programmer III, it's given me more power (The engine doesn't lug in 5th gear @ 1000RPM anymore) and it seems like mileage has improved (probably because I can actually use 5th gear at 50km/h instead of 4th) The nice thing about the Hypertech Programmer, is that some models offer tuning for 87 octane as well as 93 octane... It's nice to get a little better performace without having to spend the extra money on premium fuel... |
