Loss of power...bogging...
Old Sep 16, 2011 | 05:55 PM
wareagle_0020's Avatar
wareagle_0020 is on a distinguished road
Default Loss of power...bogging...
Got a 4.3 in a 90 blazer...its bad a huge loss of power and if i ever go threw mud or anything and put it to the floor it spits and pops and if i let go of the throttle all the way it goes dead. i have replaced plugs, wires, cap and button. adjusted the throttle body and it had a new air filter...any idea what might be doing this? its a huge huge loss of power and its killing my performance off road
Old Mar 21, 2012 | 08:31 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
cleaning the IAC might be what you need... might not be opening up fast enough as the engine returns to idle...
Old Mar 23, 2012 | 10:31 AM
SmokenJoe's Avatar
SmokenJoe is on a distinguished road
I just went through this. Felt like tranny was going. Turned out to be a blocked cat. Replaced it and now we are back to normal.
Old Mar 26, 2012 | 08:43 AM
sicks10's Avatar
sicks10 is on a distinguished road
I had the same issue with a blocked cat.. Then going down the road I heard a pop, looked in mirror, and saw a cloud of black smoke.. Haha. ROLLIN' COAL.. for a second.
Old May 21, 2012 | 10:17 PM
BigNeal's Avatar
BigNeal is on a distinguished road
What were the symptoms of a blocked cat? MY throttle response is in need of improvement and I was considering getting a catco high flow cat from my exhaust shop, but didnt know if I needed to get larger piping also, leave it or what.
Old May 22, 2012 | 09:09 AM
SmokenJoe's Avatar
Cool
For me it started with a rattle in the cat. Once it warmed up it would stop. It felt like it was being choked out. No power like the tranny was slipping. Had a hard time to rev it up. Turned out the inside of the cat broke and would block of the flow of air once it warmed up. The code that I was getting was for the MAF (mass air flow sensor). It started fine and ran perfect at low idle. Once I put my foot into it no go lucky to get 30mph. I hope this helps.
Old May 22, 2012 | 04:39 PM
BigNeal's Avatar
See Im not getting any codes, but it feels like it takes a while to build up speed/power. Like no pick up when I hit the pedal. It got better once I swapped the oem filter out with the amsoil one.
Old May 22, 2012 | 05:01 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Check EGR valve for carbon chunkage
Old May 22, 2012 | 11:42 PM
BigNeal's Avatar
I'll remove it tomorrow and see what it looks like.
Old May 23, 2012 | 12:24 AM
Jesse C Figueroa's Avatar
Jesse C Figueroa is on a distinguished road
I'm having a similar issue. I have a 89 chevy s10 blazer 4.3l v6 2wd with model 220 tbi. I changed the IACV, the coolant temp sensor, patched up fuel injector wires, and even changed the spark plugs today cuz they were real dirty. Started it up and it is still popping and running like crap. i also found a hose that got disconnected from somewhere that is severed at one end. However for the life of me I cant seem to figure out where it goes.
http://imgur.com/WfJmI
Last edited by Jesse C Figueroa; May 23, 2012 at 12:34 AM. Reason: adding a picture
