Motor
Welcome. [sm=welcomesign.gif]
That is a loaded question.
You can drop a Vortec V8 in.
You could drop just about any 4.3L V6 engine in there. All depends on how much you want to replace.
If your only looking for a Vortec engine. All 4.3L V6 engines that came in the S10's is a Vortec engine. GM modified the design over the years. Teh third generation is the one everyone typically calls a Vortec engine and it came out in '96 and later.
The key is to get the ECM and wiring harness with the engine. Since yours is a '93 it has the electroncialy controlled 4L60E tranny, any 4x4 4L60E tranny will drop in and bolt up to either hte 4.3L V6 or small block chevy V8 engine.
Like I said, that is a loaded quesiton. Could you narrow it down some?
I am currently dropping a '85 4.3L V6 from a fullsize truck into my '93 S10-Blazer. '85 was the last year of the 2 piece rear mainseal, so I have to make a custom oil pan. However the intake from the '93 will bolt up to the long block of the '87.
Unfortunately your donor is too new.
In '95 GM changed the angle of the intake to head bolts. Otherwise you could have just swapped the intakes and block sensors and been done with it. In your case, yes you need the wiring harness and the ECM.
If you did want to use your intake and your wiring and your ECM, they you need to swap the intake manifold, and both heads from your truck to the '96 engine. Personally, I would keep the '96 intact and swap the wiring and ECM. The '96 has the third generation Vortec heads and pushes more power then your '93.
ORIGINAL: moonshiner500
i was wondering what years of motor would fit in a 93 blazer that is vortech
