Piston clearance on rebuild
Old Dec 13, 2009 | 10:21 AM
WLB's Avatar
WLB
WLB is an unknown quantity at this point
Default Piston clearance on rebuild
I am helping a friend rebuild a 350 engine for his K5 Blazer. He has a ZZ3 engine that scuffed a piston when a head cracked and let antifreeze into the bore. He also has a set of new Vortec heads so that is not an issue.
After cleaning the block and lightly honing it, all 8 cylinders measure 4.002 with no measurable taper or out of round. He would like to use the block as is and not bore it so my question is, Is there a standard bore piston that would work with this much extra clearance in a street application? Horsepower will be right around 350.
He would like to avoid the expense of forged pistons but would like something a little better than cast. I'm not an authority but I don't think hypereutectic pistons would like that much extra clearance. Anyone with real world experience have any suggestions?
Thanks
Bill
Old Dec 13, 2009 | 04:02 PM
Piston OD to wall clearance is typically desired to be 0.002-0.003 for cast pistons and 0.006-0.007 for forged pistons. Since the stock bore is 4.000, I wouldn't worry much about having a 0.0020 overbore. If I remember correctly, the 350 from my Chevelle had around a 4.003-4.005 bore and I used the stock pistons with new rings. Just set your ring end gap per specs in the bores you have and you should be set.
kish2554
Jul 16, 2012 08:32 PM
K5corey
Feb 18, 2010 07:38 PM
toaks1
Sep 10, 2009 04:26 PM
lakeblazer91
Feb 18, 2009 10:06 AM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
