Positraction
Old May 16, 2006 | 01:16 PM
tbirr's Avatar
tbirr is an unknown quantity at this point
Default Positraction
I did a search and couldn't find any info on maintenance recommendations for a positraction unit. The owner's manual didn't help. The dealer says I didn't have to do anything until 100K miles. Any suggestions??
Old May 16, 2006 | 01:25 PM
Default RE: Positraction
There is no special requirements for your diff. The G80 diff isn't really so much of a friction type posi as it is a gradual locker. The G80 is actually a gov-loc differential and although it isn't as robust as either a genuine posi or a locker, it does well in stock application.
I just serviced the rear end in my Bravada a few weeks ago. Have a read through my writeup:
Rear Axle Service
Old May 16, 2006 | 03:58 PM
tbirr's Avatar
Thanks. I did see your service info, that's what I'll do. If you have a moment can you explain a little more about the G80 diff? How does it differ from a "real" posi unit? Isn't the name positraction just Chevy's name for a limited slip diff? Does the G80 use clutch plates and such and require a special additive to the gear lube?
carltwiegand
May 8, 2011 01:46 AM
Helter80
Dec 19, 2008 07:15 PM
