-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   Serp belt idler (https://blazerforum.com/forum/engine-internal-9/serp-belt-idler-2962/)
frankjc Mar 25, 2006 07:56 PM
Serp belt idler
Hi all, I am new here, this is my first post.
I have a question about the serpentine belt idler pulley in my 99 Blazer.
I bought a new one from Advance Auto parts, and it comes without the bolt. The guy said re use the old one. If I recall correctly from when I changed the water pump last year, it seemed like the bolt was part of it. Unless there is a clip in there holding the bolt in.
Anyone know?
Thanks, Frank.
4lowlife Mar 25, 2006 09:38 PM
RE: Serp belt idler
Are you trying to remove the bolt? I think you turn it clockwise to loosen it.
frankjc Mar 26, 2006 12:55 AM
RE: Serp belt idler
No, I am trying to make sure I got the correct pulley before I take it apart. The new pulley did not come with a bolt, I though the one on the car had a bolt attatched to it. I want to know if the bolt comes off of the old pulley to be reused.
Hanr3 Mar 27, 2006 03:52 PM
RE: Serp belt idler
Yes, the serp belt tensioner pulley, and serp idler pulley are both held in place with a bolt. Reuse the old bolt. Did you get the whole arm or just the pulley?
frankjc Mar 27, 2006 05:56 PM
RE: Serp belt idler
I just got the pulley. It is pretty worn.
smdepew1976 Mar 27, 2006 06:10 PM
RE: Serp belt idler
I need to replace my entire arm as i think the spring is weak....the arm moves around quite a bit and sounds like i got a cricket under the hood......anyone know of a good place to get one?
Hanr3 Mar 28, 2006 05:48 PM
RE: Serp belt idler
Most autoparts stores will sell you a new arm. Last time I priced one it was less then $20. I need to replace mine ont eh '87. It sits cockeyed and caused two ribs of the serp belt to disentigrate. The belt is a little narrower now, but it doesnt squell anymore. :D
smdepew1976 Mar 28, 2006 07:17 PM
RE: Serp belt idler
well see the part stores here in Germany just give me dirty looks when i ask for chevy parts......i guess cause the vettes are really the only chevy's sold over here....I did find one online it's 38 bucks however and i'm not sure if it's just the arm or the arm with the pulley on it....i need both......
frankjc Mar 28, 2006 10:26 PM
RE: Serp belt idler
That part is only $20? I should grab one of those too. I still haven't gotten around to the idler yet.
ORIGINAL: Hanr3
Hanr3 Apr 3, 2006 03:17 PM
RE: Serp belt idler
For our German constituants, try Summit racing, Napa, or LMC Trucks for parts online. LMC will be the best bet.
Taht $20 was for a '87. The newer ones might cost more.
