Slave cylinder
Old Feb 12, 2007 | 10:30 PM
twintrades's Avatar
twintrades is an unknown quantity at this point
Default Slave cylinder
Ok When i push down on the clutch i cant engage it. But if i lighty push a couple of times them push all the way down it will work some times. Could that be air in the line?????
Old Feb 13, 2007 | 01:23 AM
4lowlife's Avatar
Default RE: Slave cylinder
I would try bleeding it first.
Is there a whirring noise when you depress and hold the clutch? If so, that's your throwout bushing/ bearing worn out.
Old Feb 13, 2007 | 05:26 PM
twintrades's Avatar
I tried Taking off the slave and letting the bleeder out then pushing the plunger back in by hand. Then tighting it I think i just need to get some more air out that way. It just to cold ill wait till this weekend.
Old Feb 13, 2007 | 05:29 PM
4lowlife's Avatar
have someone push the clutch pedal a few pumps fully to the floor at least 3 times while its bleeding.
rickmfromnh
Aug 22, 2011 11:27 AM
MYBOWTIE89
Dec 31, 2010 12:39 PM
mbar
Nov 10, 2010 02:39 PM
rooster
Nov 15, 2006 09:27 PM
93LT
Jan 16, 2006 09:36 PM
