Slave cyl?
Old Dec 30, 2010 | 01:16 PM
MYBOWTIE89's Avatar
MYBOWTIE89 is on a distinguished road
Default Slave cyl?
I've got no pressure to my clutch pedal and ive notice the leak of clutch fluid (dot3) coming from the lower part of the truck not up by the master cylinder for the clutch my best guess is that it is the slave cylinder leaking causing no pressure to the clutch...anyone have this problem or know what else it may be?
Old Dec 30, 2010 | 06:19 PM
abig84's Avatar
or the line going to it. also ive seen it where the master will leak inside the cab then run down the carpet and leak out a hole in the floor if its rusty
Old Dec 31, 2010 | 12:39 PM
MYBOWTIE89's Avatar
Thanks, I'll make sure I run the line and check it all before i replace the slave i doubt its leaking down through the truck from the master but ill check that too, thanks for the tip.
rickmfromnh
Aug 22, 2011 11:27 AM
mattlinke
Jan 21, 2010 10:04 AM
twintrades
Engine & Internal
Feb 13, 2007 05:29 PM
rooster
Nov 15, 2006 09:27 PM
PhatKat
Mar 30, 2006 07:13 PM
