The spider
Old Aug 15, 2006 | 04:16 AM
The Sickness's Avatar
The Sickness is an unknown quantity at this point
Default The spider
I have trouble in start up. I drive a 1993 S-10 Blazer Tahoe. It is 4x4 with the 4.3 Vortec, and the automatic 4L60E. The problem is that it seems to have to turn over way too long before it finally fires up. And when in idle it sometimes acts like it is trying to die and then surge like it is catching it's self and reving up. I am slightly familiar with the Central injector unit.................the spider. Does it sound like the regulator is leaking preassure, could it be the injector unit it's self, or is it something else.
Old Aug 15, 2006 | 11:16 AM
Default RE: The spider
To diagnose a fuel system leak, you really need to monitor the fuel pressure once the pump is turned off. A leaking FPR will gradually bleed down the pressure in the supply line and may cause your hard start if there is little to no pressure.
Next time the truck sits over night, try turning on the key until you hear the pump shutoff, then try to start it. This will give the pump time to build up the fuel pressure before you attempt to start it. If it starts right away, then you have a problem with fuel pressure leak down. This can be caused by a leaking FPR or a leaking check valve in the tank.
I would suggest getting the fuel pressure checked and if a leak is detected, then pop off the plenum and pressurize the fuel system again. Look for leaks around the lines and around the FPR.
Old Aug 17, 2006 | 01:31 AM
Hanr3's Avatar
I would also look for a vacuum leak.
hunter05
35
May 16, 2024 09:01 PM
hunter05
Mar 29, 2014 11:32 AM
dougg01
Feb 6, 2010 05:16 PM
wythel
Aug 9, 2006 02:10 AM
PhatKat
Engine & Internal
May 29, 2006 10:35 PM
