STEAM FROM RADIATOR
Old Jun 16, 2006 | 02:20 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
Default STEAM FROM RADIATOR
STEAM IS COMING OUT OF MY RADIATOR
not from the cap. it is as if there is a crack on one of the long sides and it is squeezing out to the ends
it is 80 degrees today and the engine temperature guage in the guage cluster reads normal temperature
i am in west chester (outside of philly) PA
i probably should not drive that car to the outerbanks tomorrow like i had planned should i?
does anyone know what is going on?
Old Jun 16, 2006 | 03:32 PM
20Blazer00's Avatar
Default RE: STEAM FROM RADIATOR
ORIGINAL: BlaZeR FXB1581
not from the cap.
It is as if there is a crack on one of the long sides and it is squeezing out to the ends.
Those "long sides" are made of high temperature plastics, and if a leak occurs it would be cheaper to replace the radiator. This makes radiator repair nearly impossible if not expensive. There is a better than OEM radiator available for our trucks, here is a link to a page that shows stock vs new, http://www.s-10crewcab.com/og1/modinfo/rad/rad.htm.
When my radiator needs replace this is what I will buy...
Clann91
Oct 21, 2013 06:59 AM
Blazer_LT
Jun 12, 2012 11:38 PM
big armo
May 12, 2011 11:43 PM
Dadet55
Nov 21, 2008 08:15 AM
Shaftjohnny88
Jun 4, 2005 07:58 PM
