Trailblazer brakes
Old Feb 5, 2005 | 06:54 PM
JayBacca's Avatar
JayBacca is an unknown quantity at this point
Default Trailblazer brakes
Hi, i have a 2004 Trailblazer, and i started having problems with my brakes..
When ever i use the brakes, even if slowing down 10mph a time, the brakes shudder under my feet, and the entire vehicle, shakes slightly... This didnt use to happen before, but now it has increased, if anyone has an idea on what this problem might be, i would be really greatful... Thank You...
Old Feb 5, 2005 | 09:53 PM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: Trailblazer brakes
Have you checked it for warped rotors?
Old Feb 6, 2005 | 10:39 PM
JayBacca's Avatar
Umm, no, i havent done that, but thanks a lot for the help, after you posted the possible problem, i checked some more sites online, and the symptoms seem to match the problem of warped rotors. Should i turn the brakes, or would the problem still repeat after a while... Or, would you recommend just replacing them althogether? Thanks a lot for the help.
Old Feb 7, 2005 | 12:56 AM
01xtreme's Avatar
That depends on how bad your rotors are warped (If they even are). If they are warped pretty bedly, then replace them. If they don't seem that bad, go ahead and turn them.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
slammedltz
Jul 15, 2006 10:06 AM
