-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   transmisson (https://blazerforum.com/forum/engine-internal-9/transmisson-2166/)
BlaZeR FXB1581 Jan 24, 2006 10:13 PM
transmisson
if i hit the gas somewhat hard....i can hear gears grinding.........are there any possibilities other than my transmission is about to die?
20Blazer00 Jan 26, 2006 04:28 AM
RE: transmisson
I would guess transfer case or rear differential (2wd); front, rear differential or transfer case (4wd)... the only other items to check are motor mounts if one is broken then the motor can shift and might cause some items to grind against each other, but this is very rare...I remember owning a '65 Malibu and I would hear a clunk in the engine compartment when I accelerated hard from a stop....found out the previous owner beat the **** out of the car by drag racing it so I had to replace the motor mounts and that fixed the problem, got back some performance too...but I digress....
An automatic has very few "gears" in it. They have splines on the input and output shafts. And the only gears are in the "Sun Planetary Gears", these would be the only gears in the tranny that I have heard of and I have read on other boards that this is a part that does have problems for the tranny in the Blazer/S10 trucks....
4lowlife Jan 26, 2006 04:30 AM
RE: transmisson
Is the fluid level up to par? An auto tranny is a hydraulic pump basically
BlaZeR FXB1581 Jan 26, 2006 08:47 PM
RE: transmisson
i checked the fluid levels and they are up to par....i think i m going to bring it to the mechanic to check out
4lowlife Jan 26, 2006 10:12 PM
RE: transmisson
Ok, let us know what its diagnoses is.
I was thinking this spring to install a Jetperformance kit, -click- when I change filter and fluid. Not sure if I want to mess with factory set shift points though.
Bocomo Jan 27, 2006 01:21 AM
RE: transmisson
I saw that in a catalog and was wondering about it. If you do install one do a report on it.
4lowlife Jan 27, 2006 07:45 PM
RE: transmisson
I will post one. Won't be until March when it warms up out there. It'd darn cold in the barn.
