Tune up
Old Jan 23, 2011 | 10:41 AM
99 blazer's Avatar
99 blazer is on a distinguished road
Default Tune up
Im going to do a tune up in a few weeks and was wondering what parts to use? what plugs,wires, and any other stuff Ill need..
Thanks
Old Jan 23, 2011 | 02:00 PM
rriddle3's Avatar
Safest bet - AC/Delco.
Old Jan 23, 2011 | 02:33 PM
99 blazer's Avatar
Ok advace sells Ac/delco..Ill do them for wires and plugs what else should be done? its has 102,000 on it..Im goin to do fuel filter too
Old Feb 9, 2011 | 08:04 PM
DannyC's Avatar
DannyC is on a distinguished road
I work at Advance Auto Parts. Go for the Autolite Professional wires. They are cheaper than the AC Delco. You can go with AC plugs or Autolite. I've used both and Prefer the Autolite. I even run them in my Harley.
Old Feb 9, 2011 | 11:21 PM
old skool luvr's Avatar
when you do a tune up 99 Blazer, it's way more involved than just plugs & wires.
cap & rotor are a must. as well as all filters. that includes air, pcv, as well as fuel.
i'm with Rich (rriddle3) on this, AC Delco.
Old Mar 12, 2011 | 09:45 AM
Senshi09's Avatar
Senshi09 is on a distinguished road
this might be a little late, but make sure you change ALL your fluids. Oil, trans and even coolant. Along with the filters of course. No sense is changing the top end stuff, (cap, rotor, plugs and wires) if your running sludge thru your motor and trans. When you get to the oil change, id get the synthetic kind. Bit more pricey but well worth it. I run full synth in my wifes car and my blazer. I was told that it helps break down and remove the sludge build up already in the motor. And when you do your fuel filter, grab a couple bottles of Lucas Injector Cleaner. Dump one bottle in each time you fill the tank. This will help clean out your fuel system and give you better MPG and extend the life of your injectors.
**EDIT**
From what ive been told by people at AZ and AA AC Delco is what these trucks like to have in them.
swartlkk
Performance & Brainstorming
29
Dec 10, 2010 09:55 AM
88s10Blazer
Jan 7, 2010 01:56 AM
97blazer617
Nov 17, 2009 08:31 PM
Bocomo
Engine & Internal
37
Feb 1, 2006 11:32 PM
blazin4eva
Feb 12, 2005 10:42 AM
