v8
Old Sep 24, 2006 | 05:03 PM
mikehillis1@yahoo.co's Avatar
mikehillis1@yahoo.co is an unknown quantity at this point
Default v8
if i drop a v8 can i use the same trans from my 4.3 v6
Old Sep 24, 2006 | 05:14 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
Default RE: v8
yeah the SBC and 4.3 use the same bellhousing pattern
Old Sep 24, 2006 | 07:38 PM
Default RE: v8
what about the computer and stuff
Old Sep 24, 2006 | 08:16 PM
Default RE: v8
Well, any swap would need to have the PCM upgraded... That is unless you are going from a TBI 4.3L to a TBI 350. If that was the case, then I think that many have been plug-n-play. For a CPI to v8 application, you would need some pretty good modification of not only the wiring, but the PCM as well. For the SCFI 4.3L (96+), you're looking at a bit of wiring, then just flash the v8 engine management software to your PCM and drop in a SCFI 5.7L v8 (which is what I am currently hunting parts for).
