v8 Swap
RE: v8 Swap
The 4.3 being a close relative to the 350/5.7L is a very potent, and underestimated engine. If you're not building a drag truck, and are merely looking for a little more power and torque, the 4.3 can be a great engine to work with.I myself plan on building up a 4.3 to give me the power I want, and should be able to handle my torque needs as well.
Here are a few articles to give you an idea of the 4.3/262's potential:
http://www.hotrod.com/techarticles/e..._engine_build/
http://www.hotrod.com/techarticles/e...all/index.html
Yes, 500 horsepower.
A quote from the last article: "...it would be more prudent to fling a bigger blower pulley on there to calm down the boost, then be happy making a stone-reliable 450-475 hp all day long on 91 octane. Put that in your S-10 and smoke it. " - HOT ROD
RE: v8 Swap
Is your blazer fuel injected or carb? going to look over the articles. beacuse I'm just lacking in power badly with the tires I am currently running on my blazer when I tow anything.
RE: v8 Swap
Seems like there is quite a bit to do, what would be the cost to do all that? why is that one carb and not fuel injected?
RE: v8 Swap
Not sure, It appears to be for only the older 4.3 and not the newer models. Could be wrong. But in the one article is said something about 89-92 or 91 model 4.3. Wouldn't be bad to know if it would work with the newer 4.3. If so it might be easier than doing a swap. Depending on if you could do it yourself or if you would have to have a garage do it.
