01 Blazer Heater does not get very Warm? Can anyone help
Old Mar 6, 2012 | 09:23 PM
ccross13126's Avatar
ccross13126 is on a distinguished road
Default 01 Blazer Heater does not get very Warm? Can anyone help
The heater in my 01 Blazer does not blow very hot air. It gets up to about 210 on the temp gauge. Occasionally if I am running the heater it will cut out and then come right back on. Not sure if these two things are related but I am wondering where to start with diagnosing this.
Old Mar 6, 2012 | 09:59 PM
derek2012's Avatar
derek2012 is on a distinguished road
sounds like your heater core is plugged. check and see if the heater hoses are both hot or one hot- one cool/ luke warm. if one is alot cooler, there isn't enough coolant flow through the heater core. also, check and see if there is a valve on those lines (sometimes they get stuck and restrict flow to the heater core)
Old Mar 7, 2012 | 11:54 AM
barr123's Avatar
barr123 is on a distinguished road
I would pull & replace the thermostat. Its only 2 bolts and 7 bucks. Wrap rags about the area because some A/F will come out of the upper tube. Doing what derek said would confirm the stat failure. Good luck, my problems a little bigger. lol
Old Mar 7, 2012 | 12:07 PM
I had the radiator flushed so if there was a clog it seems like I would have noticed it then. I am wondering if the heater control isn't bad. Is this possible?
Old Mar 7, 2012 | 12:20 PM
pettyfog's Avatar
Ummm.. no. Leave the thermostat alone, it only controls flow to radiator, not heater. IT DOES help engine warm quicker.
That's assuming your temp gauge does not go above approx 210. AND that...
When you check the radiator coolant level cold at least once a week, it is full to the cap.
That's very important in these trucks as most can attest.
Then Derek is right. Warm the car, turn on blower high. check those heater lines at firewall
1 warm, 1 cool - blocked
Both warm or othe r slightly cooler - probably the blend door actuator.
Search
blend door actuator replace site:blazerforum.com
Now as to 'cutting out'..what cuts out. the blower?
Old Mar 8, 2012 | 07:32 AM
Yes the blower cuts out.
djmehkae
Nov 7, 2017 08:08 PM
danb2760
Dec 24, 2010 04:08 PM
juicy_jay_510
Nov 28, 2008 01:28 AM
RZS2000Blazer
Feb 11, 2008 02:11 AM
Inferno
Oct 22, 2006 08:56 PM
