01 Blazer AT wont shift
Old Jul 7, 2011 | 03:03 PM
pcurrie621's Avatar
pcurrie621 is on a distinguished road
Default 01 Blazer AT wont shift
I have a 01 Blazer AT. While driving on the beach in 4wd my check engine light came on and the truck wouldn't shift out of 3rd gear. I can manually shift between 1st, 2nd, and 3rd on the column fine, but when I put it in D it is stuck in 3rd. I checked the codes and I had error for all the transmission solenoids 1-2, 2-3, 3-2, TCC, and TCC PWM. I replaced all the solenoids but still have the same problem. Any suggestions will be greatly appreciated. Thanks.
Old Jul 7, 2011 | 03:54 PM
Check the CLSTR fuse in the instrument panel fuse box. It provides power to all of those solenoids.
Old Jul 7, 2011 | 04:54 PM
pcurrie621's Avatar
Swartlkk, Thanks for responding. I checked the fuse and it is good.
Old Jul 7, 2011 | 05:10 PM
Next, check for power to the solenoids with the key on. You may have broken the wire at some point during your offroading trip.
Old Jul 7, 2011 | 05:54 PM
pcurrie621's Avatar
Can I check for power in the harness somewhere before it enters the transmission? If I can avoid it I would rather not drop the transmission pan again.
Old Jul 7, 2011 | 05:58 PM
Yes, it will be the pink wire at pin E in the main transmission connector located on the passenger side of the transmission.
Old Jul 7, 2011 | 06:16 PM
pcurrie621's Avatar
Thanks again for the replies. It looks like I'll have to check it tomorrow. It is storming terrible here now, but I'll let you know how I make out tomorrow.
Digitized
Jan 12, 2014 12:07 PM
dj00140
May 20, 2013 06:37 PM
riggermm
Nov 4, 2009 06:06 PM
Blahman20
Nov 3, 2008 09:45 PM
cassiblazer96
Sep 30, 2008 04:14 PM
