'01 Idles at 2000 RPMS when giving slight gas shoots up to 3000 RPMS
Old Nov 21, 2023 | 02:50 PM
valkyrie's Avatar
valkyrie will become famous soon enough
Unhappy '01 Idles at 2000 RPMS when giving slight gas shoots up to 3000 RPMS
As I went to start the Blazer, I heard a pop noise from under the hood followed by a puff of smoke and a bad smell. The engine acted funny for a little bit and then it started to idle at 2000 rpm when it normally idled at 500 rpm. The service engine light came on. I tap on the gas pedal to try to get the idle to correct itself and it seemed to have a mind of its own and jumped to 3000 rpms and then slowly went back to 2000. code given is p0101
has anyone else experienced this before?
I have tried cleaning maf sensor, checking connectors/contacts, and making sure the intake is secured on right. the air filter and tb are both clean.
is there a good, hopefully easy way, to check for a possible vacuum leak?
Old Nov 22, 2023 | 12:52 AM
valkyrie's Avatar
Closing this thread as I have found my issue. The PCV had broke in two parts and was allowing a rather large vacuum leak. After replacing it, truck idles at it's normal range.
Old Nov 22, 2023 | 09:21 AM
El_Beautor's Avatar
Wow. That's kinda wild. I wonder what caused it to snap like that? Glad you figured it out quickly.
Old Nov 22, 2023 | 12:00 PM
Thanks for the update. This will be useful for others to know.
PuckinBlazer
May 2, 2020 05:57 PM
JoshyB
Feb 16, 2018 06:17 AM
BigEffingHammer
Aug 27, 2014 01:39 PM
seanblazer
Jun 3, 2013 03:53 AM
Skylar
Feb 9, 2011 03:53 AM
