01Chevy blazer
Old Jul 9, 2015 | 06:44 AM
Chevy#'s Avatar
Chevy# is on a distinguished road
Default 01Chevy blazer
4lo won't disengage back 2wd
Old Jul 17, 2015 | 01:03 PM
LesMyer's Avatar
Sounds broken! What is your question?
3 button or 4-button control? Make observatons and put a effort into describing fully if you would like us to help.
Old Jul 17, 2015 | 06:33 PM
Chevy#'s Avatar
When you put it in 4lo then try to go back to 2wd it will not. The only way it will go back to 2wd is to turn the Blazer off & leave it in neutral then press the button for 2wd. It's a 3 button system with a 4th button for auto 4wd.
Old Jul 20, 2015 | 10:44 AM
LesMyer's Avatar
So I am hearing that the 4WD is functional, but you are having trouble getting back out of 4LO unless engine is off with key on, and trans is in neutral.
I would try per instructions below. If will absolutely not work this way, then probably you have a weak Encoder motor or something binding in the transfer case. But I'm thinking you may be just fine and just need to practice getting it back ot of 4LO (which you really shouldn't need very often!).
Good luck and best wishes.
From the owners manual for auto 4WD 2001 Blazer:
Shifting Out of 4LO
To shift from 4LO to 4HI, AUTO 4WD or 2HI, your
vehicle must be stopped or moving less than 3 mph
(4.8 km/h) with the transmission in NEUTRAL (N),
or with the clutch pedal pressed for vehicles with manual
transmission, and the engine running. The preferred
method for shifting out of 4LO is to have your vehicle
moving 1 or 2 mph (1.6 to 3.2 km/h). Press and release
the 4HI, AUTO 4WD or 2HI switch. You must wait for
the 4HI, AUTO 4WD or 2HI indicator light to stop
flashing and remain illuminated before shifting your
transmission into gear.
If the 4HI, AUTO 4WD or 2HI switch is pressed when
your vehicle is in gear and/or moving, the 4HI, AUTO
4WD or 2HI indicator light will flash for 30 seconds but
will not complete the shift unless your vehicle is moving
less than 3mph (4.8 km/h) with the transmission in
NEUTRAL (N) or with the clutch pedal pressed for
vehicles with manual transmission.
