02 Blazer doesn't like to go over 30-35mph
Old Nov 25, 2018 | 02:13 PM
Blatt02's Avatar
Blatt02 is on a distinguished road
Default 02 Blazer doesn't like to go over 30-35mph
I have an 2002 Blazer and I have an issue with it...
It will accelerate fine until it hits 30 mph. The RPM's spikes and it doesn't go over 35 mph. I have a transmission fluid leak (No clue where), but I put more Tranny fluid in it and drive it around a bit, but it still does the same thing. It throws NO CODES Please I would like to know what the issue is....
Thanks.
I also posted a video of what it does on youtube... here is the link
Old Nov 25, 2018 | 11:23 PM
I would say you have some sort of transmission problem. When on mine the 3/4 clutch pack went out, it would rev as if I had put it in neutral. Does yours act like that? I have also heard of torque converters failing but I'm not sure of those symptoms. What happens when you top off the transmission fluid? Does it change how it behaves? I.e. running normally until too much fluid leaks out or do the symptoms persist irrespective of the amount of fluid?
I would say a trip to a transmission shop is in order.
Old Nov 26, 2018 | 10:31 AM
Blatt02's Avatar
Symptoms don't change after i topped it off with transmission fluid... Still does the same thing. Engine does rev up as if it was in Neutral. I looked into it some more and heard stuff about my MAF (which i checked), my catalytic converter or muffler, and Spider fuel injector. Then again i replaced the catalytic converters not to long ago... but read some things about my Catalytic Converter clogging up from faulty injectors. I will most likely take it to the shop but it can get expensive and wanting to see if i can fix it myself.
Old Nov 26, 2018 | 10:41 AM
Yep, good to check the easy/cheap things first, even if they are not likely to resolve the issue. However, what you describe sounds a lot like what happened when I lost my 3/4 clutch pack. Mine failed because I towed my boat using overdrive, a big no-no. Here is a good video that explains failures that can happen with our transmissions.
If you do have to have the transmission rebuilt, consider doing the parts upgrades that will make it stronger. I had a shift kit installed, a better torque converter installed, and a remote cooler. I wish I had also looked into an upgraded planetary gear too and stronger drive shell. Apparently the 4l65e incorporated many of the upgrades and the parts can be retrofitted to the older transmission.
Good Luck!
Old Nov 26, 2018 | 11:58 AM
Transman304's Avatar
You have internal transmission problems stemming from the leak more than likely. Running low on this transmission is sure death for the 3-4 clutches. Even just a few miles will glaze and burn them. Going to need to be rebuilt or replaced. Good luck.
Old Mar 30, 2019 | 11:14 PM
J.Alan's Avatar
J.Alan is on a distinguished road
Default Check CC back pressure
You can do a quick check of the back pressure of your catalytic converter. It's pretty easy and best of all it's free if you have a vacuum/pressure gauge. I found it best to access exhaust system through your EGR ports. My jimmy had similar symptoms, my first thought was my trans. After talking with a mechanic I was told to test exhaust back pressure. Sure enough my converter was clogged. A guy on YouTube "scannerdanner" has some good videos on testing. Best of luck!
Old Mar 31, 2019 | 12:53 AM
odat's Avatar
Well since November he may be still saving for a new or maybe rebuilding the tranny but in his case he was tacking out the RPM's - in your case with a clogged cat you should of built up too much back pressure and engine should have bogged down due too lack of exhaust flow ....
Old Sep 5, 2023 | 09:20 PM
Failedblazer03's Avatar
Failedblazer03 is on a distinguished road
[QUOTE=Blatt02;698958]I have an 2002 Blazer and I have an issue with it...
Thanks.
Ok I know this is an old thread but I feel I should add my 2 cents. Mine did a similar thing but if you'd floor it it would hit 5200 RPM and 2nd gear would grab hard again and manual shift in to 2nd would keep it there. I replaced the shift solenoids and the TCPM Solenoid. The problem is actually the seals in the torque converter allowed the lock up to loose pressure and therefore loose lock up. Essential like pushing in the clutch until the pump throws enough pressure at it at high RPM to get it to relock. On rare occasions it will shift normally into 3rd and 4th and holds without issue once it's engaged.
The fix is replace the torque converter and the 2 shaft seals on the input shaft. Yes, you should have the transmission rebuilt at this point but if you catch it before you burn out the sun shell you should be able to get away with just the TC and seals and a filter and fluid change.
Cinnamon
Nov 5, 2019 02:46 PM
S10BlazerFTW
Apr 26, 2013 04:43 PM
Jakeduece
Sep 28, 2012 10:09 PM
cjpriceless
Oct 8, 2009 09:40 PM
Amish3006
Jul 27, 2009 05:44 AM
