02 Chevy Blazer into 01 gmc Jimmy engine swap
Old Jul 20, 2018 | 02:20 PM
SevereDevil's Avatar
SevereDevil is on a distinguished road
Default 02 Chevy Blazer into 01 gmc Jimmy engine swap
I took my motor out of my 4.3L 01 Jimmy and replaced it with a nearly identical 4.3L 02 Blazer engine. All plugs are connected. All 7 grounds are attached. Battery reads 12.47v No crank. Don't hear the fuel pump. Security light is on. I've tried 2 different security resets from online. Both didn't work. Starter has big wire attached and little wire attached along with wire from solenoid. Anyone have an idea as to what I may be missing? Any help much appreciated.
Old Jul 20, 2018 | 02:21 PM
Wanted to add I have aftermarket radio and no key fob.
Old Jul 20, 2018 | 02:44 PM
LesMyer's Avatar
Power goes through Ign C fuse (underhood relay center) - then through ignition switch - then through Crank fuse (underhood relay center) - then through Park/Neutral Switch - then through starter relay (underhood relay center) to Ground 102.
The circuit above trips the starter relay to supply voltage to the purple wire on the starter solenoid, the solenoid pulls back and in turn connects the battery to the starter motor which is grounded through the engine. The engine then cranks.
Anything mentioned above fails, then engine won't crank.
Has nothing to do with security system or the PCM.
Good luck
Old Jul 20, 2018 | 03:10 PM
Thank you very much for the quick reply. I realized I couldn't move from park and checked the park switch and noticed the plug was in. But not clicked in enough. Clicked it in and starts right up thank you again
djd99
Aug 9, 2018 09:50 PM
jaatecart
May 14, 2018 11:22 AM
Chevy lover 75
Mar 9, 2017 05:18 PM
overtimeracing
May 24, 2011 01:49 PM
eavaught
Sep 14, 2010 07:22 PM
