02 struggles to turnover but then runs fine
Old Jul 8, 2024 | 07:24 PM
aarondevr's Avatar
aarondevr is on a distinguished road
Default 02 struggles to turnover but then runs fine
the problem started a month or 2 ago, when i start it, it takes like 3-7 seconds to start or you just have to try again. it might just be a spark plug or electrical issue but i just want some input if anyone can help at all
Old Jul 8, 2024 | 09:31 PM
AJBert's Avatar
Use the KISS method. Do a load test on your battery first. A weak battery would cause exactly what you are experiencing.
Old Jul 8, 2024 | 10:26 PM
Old Jul 11, 2024 | 12:28 PM
El_Beautor's Avatar
Yep. What they said.
If your battery load tests fine the next step after that would be to inspect your battery cables. They're quite prone to corrosion which will cause a significant increase in resistance and difficulty supplying power to the starter.
Shane2013
Jan 16, 2017 09:44 AM
Blazer2000LT
18
Jun 8, 2013 11:18 PM
MadMatt
May 22, 2009 10:10 PM
bjam2
Dec 3, 2005 12:39 AM
bcg187
Jul 28, 2005 12:52 AM
