04 blazer 4 wd problem??, please..
![Unhappy](https://blazerforum.com/forum/images/icons/icon9.gif)
04 blazer, every hour or so while driving it acts like something is trying to engage on the 4wd. loud, fast clicking noise heard from front end. When it does this I just push 4wd auto and it goes into 4wd and stops the noise. Minute later put it back into 2 wd and it will be fine for an hour or so. Everything else about 4 wd seems fine. Mechanic has not heard it and only want it when it acts up. I am BYard mech for years but new to 4 wd problems. Thanks for any help... searched many forums and no similar issue found.
![Icon Errrr](https://blazerforum.com/forum/images/smilies/icon_errrr.gif)
I had the same problem with my 99. I'm not sure if this will help you or not as you have a solenoid on your firewall and I have a switch on my transfer case. I unhooked the vacuum line near the firewall on the drivers side and plugged the ends to keep it from happening on my way to the parts store to get a new part.
i am having somewhat the same problem with a 98 blazer in 2 hi it clunks like a mother from 30 k and higher but once i hit the button for 4hi it all goes away not sure what this is or where i shoiuld look to try and figure this problem out.
How do I know the vac solenoid is the problem? I found a broken vac line near the sol. going to replace it and try. actuator appears tight and sealed.
thanks,
Found a broken vac line at the firewall drivers side. Fixed it and has not acted up after driving for 1/2 hour. Still early but I am hopeful that might do it.
thanks,
thanks,
thanks,
https://blazerforum.com/forum/tech-articles-diy-29/4wd-front-axle-clicking-when-2hi-goes-away-when-4hi-4lo-41226/
That should answer your questions.
