04 blazer 4 wd problem??, please..
Old Oct 4, 2012 | 07:24 PM
ndet's Avatar
ndet is on a distinguished road
Unhappy 04 blazer 4 wd problem??, please..
04 blazer, every hour or so while driving it acts like something is trying to engage on the 4wd. loud, fast clicking noise heard from front end. When it does this I just push 4wd auto and it goes into 4wd and stops the noise. Minute later put it back into 2 wd and it will be fine for an hour or so. Everything else about 4 wd seems fine. Mechanic has not heard it and only want it when it acts up. I am BYard mech for years but new to 4 wd problems. Thanks for any help... searched many forums and no similar issue found.
Old Oct 4, 2012 | 08:48 PM
xgiovannix12's Avatar
are you getting any service 4wd lights on ?
Old Oct 5, 2012 | 03:31 AM
ndet's Avatar
Default blazer 4 wd pbob.
No service lights or blinking control switch issues. Sounds almost like playing cards in the spokes of a bicycle.
Old Oct 5, 2012 | 12:54 PM
aa21830's Avatar
aa21830 is on a distinguished road
Check vacuum solenoid near firewall. Sounds like you are getting constant vacuum to the actuator under the battery tray. Not advisable to drive too much in this condition.
Old Oct 5, 2012 | 06:23 PM
99lsdriven's Avatar
99lsdriven is on a distinguished road
I had the same problem with my 99. I'm not sure if this will help you or not as you have a solenoid on your firewall and I have a switch on my transfer case. I unhooked the vacuum line near the firewall on the drivers side and plugged the ends to keep it from happening on my way to the parts store to get a new part.
Old Oct 5, 2012 | 09:31 PM
jrb_fishy's Avatar
jrb_fishy is on a distinguished road
i am having somewhat the same problem with a 98 blazer in 2 hi it clunks like a mother from 30 k and higher but once i hit the button for 4hi it all goes away not sure what this is or where i shoiuld look to try and figure this problem out.
Old Oct 6, 2012 | 08:54 AM
ndet's Avatar
How do I know the vac solenoid is the problem? I found a broken vac line near the sol. going to replace it and try. actuator appears tight and sealed.
thanks,
Found a broken vac line at the firewall drivers side. Fixed it and has not acted up after driving for 1/2 hour. Still early but I am hopeful that might do it.
thanks,
Old Oct 6, 2012 | 11:48 AM
50lb_cat's Avatar
Old Oct 6, 2012 | 11:11 PM
99lsdriven's Avatar
Got my fingers crossed for ya.
Old Oct 15, 2012 | 11:45 PM
jrb_fishy's Avatar
i am not to sure on what is going on with the truck so far i cant seem to find the problem i am going to keep looking
