'05 4x4 shifting problem
Old Dec 11, 2008 | 03:49 AM
dump_guy's Avatar
dump_guy is an unknown quantity at this point
Default '05 4x4 shifting problem
Short & sweet. Used to not shift into 4hi on occasion. Sometimes had to push 4hi twice. Now won't shift at all into 4. Tried stopping & shifting in neutral. When I try to engage 4 wheel drive, 4hi & 2hi flash simultaneously then go back to 2hi. Doesn't appear to be any noise when this happens. Actuator?? Sensor?? Vacuum??
[&o][&o][&o][&o][&o][&o][&o]
Old Dec 11, 2008 | 06:40 AM
rriddle3's Avatar
Default RE: '05 4x4 shifting problem
MOVING TO ENGINE AND TRANSMISSION
Old Dec 11, 2008 | 07:58 PM
pigpenlou's Avatar
pigpenlou is an unknown quantity at this point
I have an 05 also - just found out today that there are problems that require the transfer ase to be taken apart and looked at. I wonder if this is 'possibly' a defect? How many miles do you have on yours?
Old Dec 12, 2008 | 07:54 AM
I would highly doubt that you need to remove and disassemble the transfer case to determine the cause of the problem.
Do both of you have the Auto4wd option?
Old Dec 14, 2008 | 04:56 PM
pigpenlou's Avatar
Mine has the auto 4 option. When I put it in that I hear a noise only when I turn. When I put it in full-time 4x4 loud clanking. Dealer had taken the transfer case off and determined that the problem was not in my front differential.... They need to take the case apart in order to "fully diagnose" the problem. It has been recommended that I do not drive the vehicle... they think the rear wheels could 'lock up' at any given time. Any thoughts?
ryndraeger
Mar 12, 2014 09:51 PM
Dozer
Jan 9, 2012 12:56 PM
Litehwk356
Mar 9, 2010 09:33 PM
jbouchard09
May 14, 2008 09:11 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
