05 Jimmy crank no start
Old Dec 27, 2023 | 11:15 AM
LilJimmy05's Avatar
LilJimmy05 is on a distinguished road
Default 05 Jimmy crank no start
Went for holidays and left the Jimmy for 4 days. Came home last night and started her up, and it ran fine. Idled at 900, let her run for a few minutes and turned it off. Wake up this morning to a crank no start. Foot to the floor, no go, flooded engine and smells of vapour. Sounds like some misfires too. Spark plugs haven’t been done in two years. Distributor cap is original. Where should I start looking for problems?
Old Dec 27, 2023 | 05:17 PM
GeorgeLG's Avatar
I am assuming that you have a strong crank but no start condition, is that correct?
  1. Any codes?
  2. What is the resting voltage at the battery terminals?
  3. What is it during crank?
  4. Pull a couple of plug wires and see if you have 1" of strong blue spark with a normal cadence during a crank
  5. Perform the fuel pressure test in the sticky
Report back and we will get you running again.
George
Old Dec 28, 2023 | 10:03 AM
LilJimmy05's Avatar
  1. Any codes?
George
battery is sitting around 12v when cranking. I don’t have a voltmeter, but that’s what the dash is telling me. I pulled the fuel pump relay and had it fire for half a second, then it died out. It smells of gas so I don’t think it’s a fuel issue. I flooded the engine pretty bad yesterday, so I let it dry out overnight
Old Dec 28, 2023 | 10:21 AM
LilJimmy05's Avatar
  1. Any codes?
George
I put the fuel relay back in and had it fire right up. Not sure what the problem could be. It’s been up and down temperature outside these days so made condensation got in?
Old Dec 28, 2023 | 10:25 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
So are you up and running then? Sometimes it's just a bad connection and pulling a fuse, relay or wire connection and putting it back solves the problem.
Old Dec 28, 2023 | 10:40 AM
LilJimmy05's Avatar
What could be the root cause of that happening? I want to replace the fuel pump relay now along with the spark plugs. I haven’t exactly kept up on yearly maintenance
Old Dec 28, 2023 | 10:43 AM
GeorgeLG's Avatar
If you follow my steps we can figure it out. This works best when it wont start.
George
Davenmike#1
Aug 25, 2022 10:47 PM
Nativewayz
40
Apr 21, 2020 01:38 PM
haliphics
Feb 13, 2016 07:22 PM
nitro7
Mar 26, 2010 10:19 AM
copper_eyes
Jan 12, 2008 12:11 AM
