10 sec then Full Rev, no movement
Old Oct 19, 2022 | 08:24 PM
Zsadist0417's Avatar
Zsadist0417 is on a distinguished road
Default 10 sec then Full Rev, no movement
It's been awhile. Last time I posted something in here, I tore a tranny out of the Red '98 Jimmy. Put a newer 90k mile trans in it. Don't remember how long it's been, but now I'm having issues with it too.
Never heard of this happening but maybe one of you have. So basically, when I start it up, I have about 10 seconds to drive it before it just revs and doesn't go anywhere. Full Rev, no movement. During those 10 seconds, it has every bit of power and will still squeal tires if you tromp on it. It's never slipped before and that's kinda extreme.
I can shut it off for a minute, start it back up and get another 10 seconds. Yes, it has fluid. Made no noises aside from my squealing breaks and the wheel bearing. All I know, haven't driven it since I got it home about a week ago.
Was thinking solenoids are shot but I don't know enough about transmissions to make an accurate guess. Any help is appreciated
Old Oct 21, 2022 | 01:01 PM
Still nothing? Nobody irl can figure it out and I really don't have the cash to pay someone to look at it. This vehicle is my only legal one and is my lifeline. OBD scanner comes up clean aside from what I already know is broke
Old Dec 9, 2022 | 09:05 PM
APrestofilip's Avatar
APrestofilip is on a distinguished road
Default Same issue
Did you ever find a resolution to this ? I’m having the same exact issue right now.
Old Dec 10, 2022 | 12:50 PM
LesMyer's Avatar
Clutches burn up and material goes into pan. Then gets sucked onto the filter, impeding flow to the pump. Shut it off - some material falls off. Run it again it it quickly plugs it again. This is my guess. Happened to me many years back on my Blazer - but I would get about a block before trans would start howling and no go. But engine was completely warmed up and fluid was thinned out.
Old Dec 10, 2022 | 03:44 PM
Thank you for such a quick reply and it completely makes sense. I’ll let you know how it worked whe I change it in the next few days. Thank you again
Old Dec 13, 2022 | 12:57 PM
Well that’s what it was, a clogged filter. Drained, flushed and replaced the filter and it drives and shifts perfect. Thanks again guys !
Old Dec 13, 2022 | 01:08 PM
LesMyer's Avatar
Glad it's working again. Just remember you will have trouble with the transmission later due to the burnt clutches.
Old Dec 13, 2022 | 02:25 PM
Gotcha. Just trying to milk a little more time out of it before i LS swap it and rebuild the tranny later next year.
Old Dec 14, 2022 | 08:29 AM
LesMyer's Avatar
Good luck and best wishes.
Yea, I play with my jimmy
Nov 19, 2021 01:16 AM
megan1993
Oct 29, 2014 10:36 PM
joeazevedoiii
Nov 2, 2010 11:41 PM
colorado99zr2
Jul 29, 2010 07:26 PM
hubbmatt
Mar 20, 2009 12:41 PM
