180* vs stock temp thermostat results
Old Feb 26, 2012 | 09:41 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Default 180* vs stock temp thermostat results
Background : 1995 2 door blazer with 4.3 /4L60e trans.
New radiator , water pump , hoses and new superstant thermostat . I'm in S. Florida so having "heat" in a car is ... so I opt for the 180* listed on Napa's computer and install above components .
Good to go !
EXCEPT for the crazy high oil pressure at idle of like 50 , and the harsh delayed 1-2 shift points from the transmission . Engine idle higher and gas mileage dropped .
Back to Napa I go , pick up a replacement superstant @ 195* this time . Easy swap-out .
Results ?
You wouldn't think a thermostat would make such a difference in the engine operating and drive-ability of a vehicle . Engine Idle back to 650-700 , normal 35 oil pressure at idle warm and transmission shifts in normal RPM range - not wound out all the time .
Old Feb 26, 2012 | 09:49 PM
xgiovannix12's Avatar
bad idea putting an 180 in these trucks
These engines love to run hot if they dont reach around 195 they run terrible and the gas mileage drops big time
justblazin1
15
Feb 4, 2013 11:53 AM
zakm0n
Jan 9, 2011 07:31 PM
PaulO2288
Aug 26, 2009 03:04 PM
timetoblaze
Engine & Internal
Feb 18, 2005 04:18 AM
2001Blazer4x4
Engine & Internal
Feb 18, 2005 04:07 AM
