1983 two wheel drive, v6 automatic transmission?
Old Feb 26, 2008 | 04:35 PM
Teisco's Avatar
Teisco is an unknown quantity at this point
Default 1983 two wheel drive, v6 automatic transmission?
What automatic transmission is in my 1983 s10 blazer 2 wheel drive v6? Also what other transmission will fit with no alteration?
I was told that is was smaller than a 350 trans.
Thanks,
Paul
Old Feb 26, 2008 | 04:59 PM
neo71665's Avatar
Default RE: 1983 two wheel drive, v6 automatic transmission?
700r4 is behind it, 700r4 out of 1982-1988 s-series 2wd fit with no mods.
Old Feb 26, 2008 | 05:13 PM
Teisco's Avatar
Thanks, that is not the 700 trans that is in Suburbans is it? Is it a physically smaller trans than a 350?
Are they hard to find?
Reason is mine is slipping and I might need another one.
Thanks again,
Paul
Old Feb 26, 2008 | 06:04 PM
Teisco's Avatar
I checked the throttle valve cable and it was lose. Is it supposed to go back on its own at low throttle or stay lose? Mine is lose and when I pull it all the way it just stays there.
Old Feb 26, 2008 | 09:27 PM
neo71665's Avatar
Same tranny as the V8s internal, tranny housing different. Your talking a 90 degree bellhousing (4.3, v8) compared to a 60 degree (2.8). I've heard you can use the auto out of a 3.1/3.4 camaro you have to change the tail shaft tho. I don't know for a fact if that true.
your cable is fine
mirrorimij
Jun 8, 2019 03:34 PM
mxpxpunkrock1987
Feb 4, 2011 01:42 PM
UndeadPrincess
Jan 28, 2011 11:25 PM
lizzj70
Jun 23, 2010 06:57 PM
The_Beast
Mar 27, 2010 06:32 PM
