1984 2.8L firing order
Old Mar 29, 2010 | 09:16 PM
mrakes's Avatar
mrakes is on a distinguished road
Default 1984 2.8L firing order
This is actually a 1984 GMC S15 that I am working on, but I am assuming a Blazer/Jimmy setup is the same.
2.8L carb motor. 5-spd
According to everything else I found on the internet, the distributor is 1-2-3-4-5-6 clockwise and the firing order is (front to back) 1-3-5 on passenger side and 2-4-6 on driver side. If I hook up plug wires in that order, engine will not start.
If I hook up the distributor 1-2-3-4-5-6 clockwise and the engine (front to back) 1-3-5 driver side and 2-4-6 on passenger side, engine will start but idle is extremely rough and engine dies. If you keep engine 1500+ RPM the engine runs smooth.
Any help here greatly appreciated.
Old Mar 29, 2010 | 11:16 PM
neo71665's Avatar
Sounds like you have the dizzy 180 degrees out.
The order is 12345 and 1 is on the pass side. 1 on the cap should be about at the 7 o'clock position.
Old Mar 31, 2010 | 09:47 PM
mrakes's Avatar
Got it. dist was out. Runs great now
jerseyjim
Engine & Internal
Jan 17, 2007 12:14 AM
Dj7763
Jan 10, 2007 06:03 PM
USMaverick101
Oct 20, 2006 06:46 PM
tesshin
Sep 11, 2006 10:05 PM
Rahmir
Aug 16, 2005 12:52 PM
