1994 Chevy Blazer Full Size oil drain?
2 Attachment(s)
I have a 1994 Chevy Full Size Blazer 4x4 with the 5.7 350
my oil pressure started acting up the other day and my CEL came on. got underneath it ad looks like its leaking some.. not sure where its leaking, but I want to do a fresh oil change and get it to a shop... is this the drain plug, and oil pan? https://blazerforum.com/forum/attach...ine=1357868795 https://blazerforum.com/forum/attach...ine=1357868795 pretty sure the tranny is leaking too, has been sitting for a while and rarely driven.. |
yeah thats the drain plug and the oil filter right above it. but i would say that the tranny isnt leaking, i would say that its a rear main seal. need to pull the oil pan if its not a one piece. and you need to pull the trans back.
good luck. |
Originally Posted by Twip
(Post 561287)
good luck. im going to do a oil change and probably stick it in a shop...not set up to do that myself |
