1994 Chevy Blazer Full Size oil drain?
Old Jan 10, 2013 | 07:46 PM
Fullsizeon38s's Avatar
Fullsizeon38s is on a distinguished road
Default 1994 Chevy Blazer Full Size oil drain?
I have a 1994 Chevy Full Size Blazer 4x4 with the 5.7 350
my oil pressure started acting up the other day and my CEL came on.
got underneath it ad looks like its leaking some..
not sure where its leaking, but I want to do a fresh oil change and get it to a shop...
is this the drain plug, and oil pan?
pretty sure the tranny is leaking too, has been sitting for a while and rarely driven..
Attached Thumbnails 1994 Chevy Blazer Full Size oil drain?-c34ac3db-613a-4b0a-a818-de92f12975ac-486-000000860965ef64.jpg   1994 Chevy Blazer Full Size oil drain?-a235025d-21da-4211-8542-3c3c0530a274-486-0000008601fad3c8.jpg
Old Jan 10, 2013 | 11:31 PM
Twip's Avatar
yeah thats the drain plug and the oil filter right above it. but i would say that the tranny isnt leaking, i would say that its a rear main seal. need to pull the oil pan if its not a one piece. and you need to pull the trans back.
good luck.
Old Jan 11, 2013 | 05:52 PM
good luck.
if the rear is leaking would it be leaking tranny fluid? oil is def leaking and there is some red fluid also
im going to do a oil change and probably stick it in a shop...not set up to do that myself
admathi
Dec 15, 2019 04:24 PM
grimreper912003
Dec 29, 2009 10:28 PM
SweetZRag
May 11, 2009 02:20 PM
Z Fury
Jul 14, 2008 08:36 AM
