1995 4l60e
Old Feb 11, 2011 | 07:12 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
The 3-4 shift 'is directly controlled by the hydraulic circuits in the valve body.'
It does say to check engine speed (tach) sensor, pressure switch assembly, brake switch, system voltage and TCC solenoid.
You'd have to pull the pan to check the solenoids and switches - you'd be measuring resistance.
Old Feb 13, 2011 | 09:44 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
a 1995 blazer with a bad shift seleniod would thorw a check engine light, no need to drop the pan and check ohms.
Old Feb 13, 2011 | 09:51 AM
That depends if he has OBD II, OBD 1 or OBD 1.5.
Old Feb 13, 2011 | 05:09 PM
if its a 95 then their is no way it has OBD1, 1994 was the last year for OBD1 in the S10 blazer, It has OBD 1.5/2 so it will set a code if their is a problem with the shift seleniod or circitry.
Old Feb 13, 2011 | 08:23 PM
Originally Posted by Ryanmatt135
if its a 95 then their is no way it has OBD1.
Wrong!
Besides, I have changed solenoids to fix transmission shifting issues where there were no stored OBD2 codes on a few different vehicles.
Old Feb 13, 2011 | 08:42 PM
^ thanks, Kyle.
Old Feb 21, 2011 | 09:28 AM
dreadinger's Avatar
dreadinger is on a distinguished road
Just found out the guy I bought it from removed the bulb from the check engine light, I replaced it and it is on. The ECM is mounted on the the passenger side fender, the decal says it is OBD1 and the connector is OBD11 but looks like it only uses 5 pins. I am assuming it is the dreaded OBD1.5, how do I pull codes from this before I pull the tranny?
dj00140
22
Nov 4, 2015 05:03 AM
scphill34
Mar 22, 2013 07:43 PM
an240172
Sep 7, 2009 02:58 AM
doubleuap
Nov 10, 2008 12:34 PM
95blazer8620
Oct 19, 2007 01:26 PM
