1995 Blazer tranny fun!
Old Aug 19, 2010 | 03:12 PM
dedmammal's Avatar
dedmammal is on a distinguished road
Default 1995 Blazer tranny fun!
hey ya'll! i have a '95 blazer i just changed the filter and fluid on.now it seems to be leaking between the tranny and engine.it reads full cold(when cold),but nothing on the stick when hot.also,doesn't want to pull on flat ground but will pull(not RUN) uphill.go figure...any ideas?
Old Aug 19, 2010 | 04:53 PM
You are reading the level with the engine running and the truck on flat/level ground, right? You should fill it with the transmission warmed up.
Old Aug 19, 2010 | 11:38 PM
dedmammal's Avatar
that i did.shouldn't have messed with it."if something works don't fix it". lol!!
Old Aug 19, 2010 | 11:55 PM
Glad you got it fixed!
Old Aug 20, 2010 | 07:06 AM
dedmammal's Avatar
oh,it's far from being fixed.the leak's still there.figure the new filter increased pressure and blew the seal.haven't started yet,so stop me if you think it's something else!! lol!!
Old Aug 20, 2010 | 07:20 AM
Oh. Guess I read your post wrong.
So the leak is between the engine and transmission? Like a front seal leak? or is it the pan gasket?
Old Aug 20, 2010 | 07:42 PM
dedmammal's Avatar
gotta be the front seal.pan gasket's snugged up,no prob there.
Old Aug 22, 2010 | 12:34 PM
Sounds like you'll be dropping the transmission in the near future. But I would recommend you clean the areas well and see if you can pin point the source of the leak.
Old Aug 25, 2010 | 09:19 PM
dedmammal's Avatar
appreciate it!! not looking forward to crawling around in the gravel again though! lol!!
Jschlact
Jul 26, 2009 11:28 PM
Tippman7641
May 22, 2008 09:33 PM
wesmagyar
Jan 31, 2008 09:30 PM
02 Vortech
Feb 12, 2007 06:40 PM
AutomagicLS1
Jan 31, 2007 04:38 PM
