1995 chevy blazer vacuum issue
Old Apr 5, 2020 | 11:27 AM
tplante72's Avatar
tplante72 is on a distinguished road
Default 1995 chevy blazer vacuum issue
I have a 1995 chevy blazer with a 4.3l v6. The previous owner thought he knew what was wrong and just pulled out all the vacuum hoses and never replaced them. Now I have no idea where any of the go, what sizes, any t's, and couplers, etc. I'm really wanting to get this running for my son. Any help will be appreciated. Thanks in advance.
Old Apr 5, 2020 | 02:18 PM
There should be a vacuum hose diagram on the underhood emissions label. If not, it's pretty easy to look up. What's your engine code (8th digit of VIN)?
Old Apr 6, 2020 | 12:33 PM
Mods's Avatar
removed hoses... man does it even run after that?
Anyways - i believe christine(some numbers) has a diagram somewhere for 98+ Trucks, it should be pretty straight forward, your truck being a 95 should have CPI (black intake runner off to the drivers side of the engine bay) So all hookups start at the Plenum and move outwards. I'd start there.
Old Apr 9, 2020 | 12:32 PM
tplante72's Avatar
I have visited code w
Old Apr 9, 2020 | 02:34 PM
See if these will help you.
File Type: pdf
File Type: pdf
Old Apr 9, 2020 | 05:07 PM
tplante72's Avatar
in hose route 2, is the evap can the ball attached to the hood.
Old Apr 9, 2020 | 05:11 PM
No, that's a vacuum reservoir. The evap canister is by the gas tank, and should have a metal line that runs most of the way.
Old Apr 9, 2020 | 05:24 PM
tplante72's Avatar
so, does everything start with the reservoir? If so, then where would I put t's or other connectors? Sorry for all the questions, but, vacuum has never been my strong suit.
Old Apr 9, 2020 | 05:31 PM
Vacuum starts at the intake manifold. The diagram should show any tees, check valves, etc.
hemimotors
Dec 9, 2016 10:30 PM
chevy_blazers
Jul 10, 2014 10:44 PM
humdinga
Sep 21, 2012 07:18 PM
db13
Sep 24, 2011 01:51 PM
RickBlazer
May 26, 2010 04:33 PM
