1995 transmission problem
i just got a 1995 s10 4x4 automatic and it doesnt seem to shift into 3rd or 4th. 1 and 2 work great. after it gets to about 55 it revs way up, let off the gas it feels like it goes to 3rd but as soon as you hit the gas again its almost like its in nuetral. i just replaced the 2 shift solenoids and changed fluid and filter and it is still doing the same thing. can someone give me some other ideas? is there any way to diagnose without dropping the pan again? that was a pain in my rear. thanks for any help
Bingo... Same thing happened to me this past summer, 1st and 2nd were fine then the tach would rev up just like yours... I got lucky and only paid $300 bucks for a used 1 from a local junk yard that came out of a 4x4 S10 pickup truck... Welcome to the Forum by the way
good luck
Brad
I thought since my 98 is compatible with so many different things I assumed they all were... Now I deserve a timeout and stand in the corner for a while
This is the infamous 3-4 clutch pack failure.
Forward clutch pack
Reverse input drum with damage from 2-4 band
Forward clutches and input drum
biggermrbrute
Oct 12, 2018 07:36 AM
big3d
Apr 4, 2012 12:03 AM
