1996 4.3 wont start please help
Old Dec 29, 2010 | 12:42 PM
Here is a pretty good list of things to check:
IGNITION SYSTEM TESTING
CIRCUIT DESCRIPTION
System includes a distributor, ignition coil, ignition control module, secondary wires, spark plugs, VCM and crank sensor. Ignition system is controlled by Vehicle Control Module (VCM). The VCM monitors the information from various engine sensors, computes the desired spark timing and controls the dwell and firing of the ignition coil via an (IC) line to the ignition control module.
ENHANCED IGNITION SYSTEM CHECK
  1. Perform Powertrain On-Board Diagnostic (OBD) System Check (i.e. check for codes). If codes are present, refer to the applicable diagnostic sheet. Before clearing DTC's, use scan tool capture info to save freeze frame and failure records for reference. The control module's data is deleted once the 'Clear Info' function is used.
  2. Check spark plug wires for open circuits, cracks or improper seating of terminals at spark plugs, distributor and ignition coil before proceeding with test. Check spark at plug with J-26792 spark tester or equivalent while cranking. (If there is no spark on one wire, check a second wire). A few sparks then nothing is considered no spark. If adequate spark is present, go to HARD START diagnosis. If adequate spark is not present, go to step 3. This checks for proper output from the enhanced ignition system. The spark tester requires a minimum of 25,000 volts to operate. This check can be used in case of an ignition miss, because the system may provide enough voltage to run the engine but not enough to operate a spark plug under heavy load.
  3. Remove coil wire from distributor cap. Insert J-26792 spark tester into the coil wire and clamp the tester onto a ground. Crank engine. If adequate spark is present, go to step 13. If adequate spark is not present, go to step 4. This test separates distributor cap, rotor and ignition wires from ignition coil in order to help identify a secondary ignition system problem.
  4. Measure coil wire resistance using a DVOM. The resistance should be approximately 1000 ohms/inch. If resistance is within specified value, go to step 5. If resistance is not within specified value, go to step 32. This test checks ignition control module, connections, and wiring.
  5. Disconnect ignition coil harness connector. Probe ignition coil connector terminal C with a test lamp connected to battery positive terminal. Crank engine. If test lamp is flashing while cranking engine, go to step 7. If test lamp is not flashing while cranking engine, go to step 6. This test begins to determine if the VCM is providing a signal to the ignition control module. If the VCM is not providing a signal to the ignition control module, the problem exists between the ignition control module and the VCM.
  6. Turn OFF ignition. Probe ignition coil harness connector terminal C with a test lamp connected to battery positive terminal. If test lamp is illuminated, go to step 28. If not, go to step 9. This test checks for a basic engine mechanical problem.
  7. Probe ignition coil harness connector terminal B with a test lamp connected to battery positive. If test lamp is illuminated, go to step 29. If not, go to step 8.
  8. Ignition ON, engine OFF. Measure terminal A voltage with a DVOM connected to a ground. If DVOM measures above 10V, go to step 21. If not, go to step 18.
  9. Turn OFF ignition. Disconnect ignition control module harness connector. Check for an open circuit between ignition coil harness connector terminal C and ignition control module harness connector terminal D. If circuit is open, go to step 27. If circuit is not open, go to next step.
  10. Disconnect ignition control module harness connector. Ignition ON, engine OFF. Measure voltage on terminal A at ignition control module harness connector with DVOM connected to ground. If DVOM measures above 10V, go to next step. If not, go to step 19.
  11. Probe ignition control module harness connector terminal C with a test lamp connected to battery positive terminal. If test lamp is illuminated, go to next step. If not, go to step 23.
  12. Disconnect ignition control module harness connector. Probe ignition control module harness connector terminal B with DVOM set to AC scale connected to ground. Crank engine. Observe voltage while engine is being cranked. Voltage should be between 1-4 VAC. If voltage is as specified, go to step 20. If voltage is not as specified, go to step 15.
  13. Remove distributor cap. Check cap for cracks, moisture, carbon tracks or physical damage. If any of these conditions are present, go to step 34. If cap is okay, go to next step.
  14. Crank engine. Observe distributor rotor while engine is being cranked. If rotor did not turn, refer to appropriate REMOVE/INSTALL/OVERHAUL article. If rotor did turn, go to step 33.
  15. Turn OFF ignition. Disconnect VCM C3 connector. Check ignition timing signal circuit for an open between the VCM C3 harness connector and ignition control module harness connector terminal B. If circuit is open, go to step 24. If circuit is okay, go to next step.
  16. Probe ignition control (IC) circuit at VCM C3 connector with a test lamp connected to battery positive terminal. If test lamp is illuminated, go to step 25. If not, go to next step.
  17. Ignition ON, engine OFF. Probe ignition control (IC) circuit at VCM C3 connector with a test lamp connected to ground. If test lamp is illuminated, go to step 26. If not, go to step 22.
  18. Check for an open or shorted to ground ignition positive voltage circuit at terminal A of ignition coil. Repair as necessary. Go to step 37.
  19. Check for an open or shorted to ground ignition positive voltage circuit at terminal A of the ignition control module. Repair as necessary. Go to step 37.
  20. Check for poor ignition control module connection. If problem was found, go to step 30. If problem was not found, go to step 35.
  21. Check for a poor coil connection. If problem was found, go to step 30. If problem was not found, go to step 31.
  22. Check for a poor VCM connection. If problem was found, go to step 30. If problem was not found, go to step 36.
  23. Repair open ignition control module ground circuit. Go to step 3.
  24. Repair open IC circuit between VCM and ignition control module. Go to step 37.
  25. Repair grounded IC circuit between VCM and ignition control module. Go to step 37.
  26. Repair short to voltage in the IC circuit between the VCM and the ignition control module. Go to step 37.
  27. Repair open in tachometer signal circuit between ignition coil and ignition control module. Go to step 37.
  28. Repair short to ground in tachometer signal circuit between ignition coil and ignition control module. Go to step 37.
  29. Repair short to ground in tachometer input circuit between ignition coil and instrument cluster. Go to step 37.
  30. Repair circuit as necessary. Go to step 37.
  31. Replace ignition coil. Refer to appropriate REMOVE/INSTALL/OVERHAUL article. Go to step 37.
  32. Replace coil wire. Go to step 37.
  33. Replace distributor rotor. Go to step 37.
  34. Replace distributor cap. Go to step 37.
  35. Replace ignition control module. Refer to appropriate REMOVE/INSTALL/OVERHAUL article. Go to step 37.
  36. Replace VCM. Go to step 37.
  37. Operate vehicle within conditions under which original symptom was noted. If system is not functioning properly, repeat testing from step 1.
Old Dec 29, 2010 | 02:40 PM
gregl316's Avatar
gregl316 is on a distinguished road
well my code reader came to me in the mail today. I tested for codes and it said no codes. I through your advice subscribed to All Data and figured out how to test the coil. It tested out bad with a simple resistance test so I bought a new one and haven't gotten a chance to install it yet. I bought the best coil Napa had. My new question is should I buy name brand stuff or can I save money and get the cheaper stuff? I want it running but... I don't want to go broke but I also don't want to do the job over. two months down the road.
Thanks you I haven't figured it out yet but your giving me lots of tests to do. Your better then the manual. Where on the internet should I buy the parts (if I need any) from?
Last edited by swartlkk; Dec 29, 2010 at 03:29 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 29, 2010 | 03:31 PM
Well, get that replaced and let us know how it goes.
As far as parts go, I am rarely let down by Napa stuff. They are probably my first choice for local parts. Some stuff I only go with AC Delco though.
Old Dec 29, 2010 | 05:20 PM
gregl316's Avatar
Default new coil
installed still no go I hope I didn't waist my money. When I crank it it sort locks up for a second and then it trys to start for a second but this takes 30 secs of cranking. I sprayed starting fluid in the intake and that doesnt do a thing. I am alittle leery about it cause I had a pretty good fire last time I got a little carryed away with the starting fluid.
Old Dec 29, 2010 | 05:32 PM
If you tested the resistance and it was out of spec, I doubt it was a waste.
If this were an older vehicle, I would say your timing is off (too far advanced) due to the lockup condition you mentioned, but on your truck, it is computer controlled...
If starting fluid doesn't allow it to start, then you either have a rich condition in the cylinders or you still have a spark issue.
How far through the list above did you get?
Old Dec 29, 2010 | 05:44 PM
gregl316's Avatar
Default Vcm
Where is it?
Old Dec 29, 2010 | 05:59 PM
Geez... Please put your complete question in your post. Don't hide the bit of info in the post title...
The VCM (PCM) is located on the passenger side fender. A quick search on your part would have told you that as well.
Old Dec 29, 2010 | 06:01 PM
JustJerry's Avatar
JustJerry is on a distinguished road
Be careful with the starting fluid, you don't need much, just a small amount and to much will or can cause the engine to lock up even causing engine damage.
Back in my trucking days hauling produce we could not use starting fluid on our refer units, it would cause them to lock up and many times when they did this rocker arms would jump off and or bend push tubes & or break valve stems.
What code reader did you get?
I feel that the advise swartlkk gave you on the timing could be right on.
Old Dec 30, 2010 | 06:53 AM
gregl316's Avatar
Default test
since I cant find a parts store to test the ing module is there a way to bench test it with a multi meter?
Old Dec 30, 2010 | 07:04 AM
That I have not come across. It really needs to get heated up to test it properly as most faults are present at operating temperature and not when cold.
