1996 Chevy Blazer Black engine oil
Old Jul 6, 2012 | 12:12 AM
ChanN's Avatar
ChanN is on a distinguished road
Red face 1996 Chevy Blazer Black engine oil
Ive had this truck for about 4 months and every 3,000 miles ive changed oil, so since then i changed the oil twice. I ran an Obd reader and I got a P0300. Which is a multiple misfire which is why I looked up the code. I already changed the spark plugs, spark plug wires, distributor cap and rotor. What would be causing my oil to be black? Smoke comes out of the exhaust but not as often and it is black as well. What would be the problem?
Old Jul 6, 2012 | 12:28 AM
50lb_cat's Avatar
Most of the time random misfire is due to secondary ignition parts. The only thing left that you haven't changed is the coil, low fuel pressure can cause it as well. The black smoke is unburnt fuel. What brand did you replace everything with?
Old Jul 6, 2012 | 06:54 AM
rriddle3's Avatar
About the only thing the oil color can tell you is that it's doing its job of suspending contaminates. I suggest a used oil analysis from a place like Blackstone Labs.
blazinchevy96
Jul 29, 2011 10:24 AM
ProjectICE
Jul 4, 2011 09:38 PM
jackdaroofer
Nov 2, 2009 01:13 AM
CH@Dbee
May 18, 2009 08:40 AM
