1996 S10 blazer misfire
Old Jun 1, 2013 | 10:48 PM
Juggalo1003's Avatar
Juggalo1003 is on a distinguished road
Default 1996 S10 blazer misfire
I have a misfire in my 1996 Chevy blazer 4.3. It also has a knock as well, lifters were replaced in November. Then recently plugs and wires. The misfire is in cylinder number 5, it also has low compression in that cylinder. Any suggestions on what it might be? Could it possibly be a bent or burnt up valve, it also losses power in the high rpm range, but has all the power it should down at low rpms.
Old Jun 2, 2013 | 02:41 PM
Here's a vid of the knock in my engine
Old Jun 4, 2013 | 08:16 PM
found the problem loose rocker on the number 5 cylinder
Old Jun 5, 2013 | 08:22 PM
Turned out to actually be a bent push rod. Hope this helps someone maybe in the same situation.
Juggalo1003
Jun 1, 2013 04:14 AM
rrk03300
Nov 15, 2012 10:29 PM
Ssthorn
Apr 27, 2011 09:07 AM
HsGarage
Oct 18, 2010 03:52 PM
89S10BZer
Mar 19, 2009 07:10 PM
